Howe part #'s from the online catalog (
www.howeracing.com) are 22302 for the 4-bolt UBJ ($74.50), 22420 for the press in LBJ ($66.00), and 22399 for the boot. The .5" stud part # is 22365 for the upper and 22475 for the lower. If you're using an aftermarket UCA with a screw-in UBJ, the Chrysler UBJ housing will take the Chevy stud.
If you're planning to use the stock UCA's, look at the shim packs on both sides. The G-body has wide production variations- if you have a thick shim pack on one side, you may not get the caster you need. I have the thickest possible shim pack on the rear bolt of the pass UCA- no more threads after the nut is tight. The driver side is normal. I tried fitting a set of Robert Adams' B-body UCA's (~5/8" shorter than stock)- they were too short on the driver side. The adjustable Pole Position arms hit the pass side frame in rebound at my ride height. Slotted cross shafts for the stock arms would work, but nobody seems to make them. I'm looking at having a set made up that's stock length on the driver side and 3/8" shorter on the pass side. You can save time on the LBJ's if you can get a decent set of salvage yard LCA's. I went this route because I had to machine out the pressfit and weld in a sleeve- Howe's weren't available at the time. I also installed Del-a-Lum bushings- everything turned out well, and the car wasn't laid up for weeks.
George- If I understand the "Incredible Hulk" comment correctly, it takes superhuman strength to lock up your front brakes. If it takes more than 75-100 lbs pedal pressure something's wrong- you're not getting enough clamping force on the rotor, or the pads/rotor are glazed. Again, I haven't owned any cars with hydraulic-assist brakes, but I can't see them being less effective than vacuum-assist brakes. I can lock my front brakes with a strong pedal effort- but I'm not bending the steering wheel to do it.
You're correct about a "60%+ weight shift " being excesssive- I was thinking 60%+ vehicle weight ending up on the front tires, but didn't phrase it correctly. With respect to braking distribution matching weight transfer- this can be optimized for only one rate of deceleration. Racers have it easier compared to street cars- they just tune for the G level their tires can pull at max deceleration. Car manufacturers have to figure out what G level the average driver will experience with OEM tires on the average highway- then design for ~5% front bias- lots more variables. The Stop Tech site (wwwstoptech.com) has a good FAQ (Brake Bias & Performance, Physics of Brake Systems), and HP Books's "Brake Systems" by Mavrigan & Carley, and the "Brake Handbook" by Puhn (out of print, available via used book dealers) are good basic references.
