I'm sure most of us have either been indoctrinated by magizine/forums, come to the conclusion through reading of informed sources, or maybe even for some of us (not me by the way) through experience that given a fixed displacement, big bore, short stroke makes the most power. I'm not going to dispute that but I do have a question within a certain set of parameters that are NOT the norm for this kind of discussion.
1. I'm working with a small motor, 3.0L (183cid) turbo V6
2. I'm really rpm limited due to the design of the block (production, can't afford a Stage or TA unit), I don't want to see north of 5000rpm since it will sit there for minutes at a time WOT at Bonneville
Looking at Bore vs. Stroke ratios and this thing is ridiculously over-square in the combination of parts I have now. 3.800in bore and 2.66in stroke for at ratio of 1.429 and with 6.3in rods, that's a rod ratio of 2.368.
The other option is a 3.5in bore LC9, horrible smog 3.2L V6 with a 3.8's 3.400in strokethat is the reverse of the later 3.0L (3.8's bore, 2.66in stroke), with either an Indy 2.900-3.070in or production 3.3L 3.160in stroke cranks to still fit in under my 183.99cid displacement limit.
I have to wonder with my rpm limitations if I've taken the big bore, short stroke thing a bit too far with the current combo or am I over thinking it? Going with an LC9 based engine would require a complete retooling of my plans for everything short of the main bearings AND likely limit me to a production block but a production block that no one wants with other parts that no one wants is how I got to where I am anyway so it's not too expensive. If that buys me an engine that will make more power under my rpm target without blowing the bottom out of the block it might be worth it.
Please comment on the theoretical THEN weigh in on the practical since I'd like an education as much as I'd like a specific answer.
Thanks,
Thanks,
