I am putting a set of T&D roller rockers on my engine and have misplaced my previously written down info on adjustment.
Champion fully ported heads with PTE 218R cam is the recipe. .528"+ net lift with the higher ratio rr's........
Here is the info thus far I have gotten from a few various sources:
Get cam on base circle and with left hand move pushrod up/down (not spinning) and tighten allen screw until no more movement (zero lash). Then tighten and additional 1/4 to 1/2 turn for .028 lash. Move to next valve.
My main question is how do I get the cam for each valve on the base circle?
I remember in my instructions to adjust the exhaust valve rocker arm right after the intake valve for that particular cylinder has closed. Or maybe it was vice versa (adjust intake after exhaust has just closed).
A more detailed explanation would be great as I just want to make sure I'm doing it right the 1st time.
Engine is in the car...... but plenty of clearance on both sides to work on it.
Adding alchy injection also at the same time and fabricating a cold air setup out of cheapie ABS piping.
Hope to run in a month some 11.20's@120mph with the stock turbo on a stock shortblock, Champion irons, T&D's, 218R, THTTA 3" DP, 3.5" mandrel bent exhaust, 009's, JJ62mm TB, Spearco FMIC, and ATR headers with custom mounted alternator and no accessories. Weight without driver is 2700lbs and this is on 91 octane and alchy injection. Best run before on homeported irons and stk valves, 208/208 cam, and 2 1/2" DP with 3" nonmandrel bent exhaust was a 11.62@114mph with TC unlocked on 116 octane and 26* chip@21psi.
Thanks guys,
GNX7
Thanks guys,
GNX7
