T tomjon Member Joined Jul 11, 2002 Aug 7, 2003 #1 What are the signs of a bad MAF unit? Engine quits running? Won't start? Gas mileage? Rough idle? I don't think my Scanmaster has the flow rate readings. Thanks.
M mybuick intercooled engines rule! Joined Jul 21, 2002 Aug 7, 2003 #2 slow responce when stepping on gas. code for a lean or rich condition, mostly lean. also look at your o2 sensor readings should bounce around alot.
