I let my GN sit in the garage for approx. 6 weeks (been really busy lately). it was running perfectly when I parked it, but I started it up yesterday and it seemed like it was only running on 4 or 5 cylinders. plug wires and electrical connections checked out OK so I got out my old mechanic's stethescope and started probing around. probed around on the valve covers - valve train sounded fine, probed around on the header primaries and noticed #5 did not sound the same as #'s 1 and 3. moved on to probing the injectors - listened to all 6 injectors with the stethescope and #'s 1, 3, 4, and 6 were all making the usual "tick-tick-tick-tick" sound however #'s 5 and 2 were not "ticking". After that I noticed the exhaust did not smell the same as usual, I could be wrong, but it smelled like maybe it was running lean - it usually smells a little rich, but not yesterday. I didn't think to look at the O2 mV before I shut it down and went back inside (I was a little cranky at that point). Based on those symptoms, does it sound like I've got two stuck injectors?
Thanks for reading.
Rob
Thanks for reading.
Rob
