STROKER GIRDLED 109 ENGINE
9secWH1
Lee Thompson built 250ci TSM long block. Throttle body to oil pan. Cal Hartline tuned and made 790rwhp at 23lbs of boost. Has 2 passes on it and maybe 500 street mile. 1 1/8th mile pass setting up the car and 1 1/4 mile pass at 18lbs of boost, went 9.8 at 137. Can send the tune file to new buyer if wanted.
Girdled 109
4340 steel stroker crank 3.625
4340 steel 6.350 connecting rods
Diamond piston
Champion fuel rails
Champion 16 bolt R heads
Champion intake race ported to match heads.
Cosmetic head gaskets
218/224 billet roller cam
T&D 1.60 roller rocker non-pedestal style.
Billet double roller timing set
Sheet metal oil pan
Blue printed high volume front
cover
Accufab 70mm Throttle body
Valve Covers with built in ls coil mounts
Extra oiler for the timing chain
12.5k
Can't duplicate the engine for that price. Proven ready to go.
serious inquires only
Thanks for looking.
Steve
Girdled 109
Diamond piston
Champion fuel rails
Sheet metal oil pan
cover
12.5k
Thanks for looking.
Steve
View attachment 308502 View attachment 308503 View attachment 308504 View attachment 308505
Hey wassup I'm the one that purchase the gn from Ross can you give me a call to 3235401119
I believe it was a precision 68 3 bolt. ill check it tomorrow for sure.
Jerry ill give ya a call tomorrow
Here's a couple pictures of the motor in the car and the car running at BG in 2015.
Hate to sound rude with this question but, Why is it for sale? It looks like an awesome set up and a good price for something that's that turn key and complete.
looks differnt than picture
It's the same engine. Valve covers are different because the car still has factory A/C and the sheet metal covers wouldn't work and the throttle body had to stay because of the wiggins clamp on the the intercooler pipe? Everything else exactly the same.
Steve
