Clearing out the garage lots of stock stuff, all in good condition unless otherwise noted. Pick up preferred but will ship items that are not over sized. Shipping will be calculated, I am not looking to make money on shipping. I am located in NE Philly. If interested email to ronszy4677@aol.com. I will get back as soon as possible. Thanks for looking.
electronic a/c heat head unit controller, bought it used and have never used it $25
defrost switch $7
a/m f/m cassette eq radio unknown if cassette works since I dont own any $75
pair front eibach springs lowered 1.5 inch $50
Stock spindles machined by Baer to accept b body rotors $50
Stock valve covers $25
NIB 86 87 gn wheel caps $30 each have 3
Coolant tank $15
Blower resistor $7
NIB 3.8 intercooled hood emblems $30 eack have 2
Oil filler neck $10
Used 86 87 GN wheel caps $10 eack have 7
Stock breather with hose $8
Horn ring $12
NAPA mass air flow in wrapper $35
turbo shield $7
Buick hawk plate $15
p/s resevoir $50
Gn wheels good drivers set $290
Stock turbo w/waste gate no smoke spooled as should, unknown if it has been ever rebuilt off 40K car $75
down pipe $25
crossover pipe $35
stock headers $90
drive shaft $25
heads $100
upper & lower a-arms w/calipers w/ ss braided lines $90
Pulleys $65
intercooler bellmouthed w/ shroud $75
Used mass air flow $25
powder coated steering shaft $25
rear view mirror $5
throttle body glass bead and clear coated $60
Newer IAC $30
NIB washer lid $10
Newer wash bottle w/lid $15
Ash tray $10
Trans tube and stick 200 R 4 $20
Aluminum drums pair $40
intercooler fan $20
intake hose $7
d5 converter $45 worked well before removal 40k car
steel coolant lines $25
stock rocker assembly pair $35
86 ECM $75
Upper plenum $30
visors with lighted vanity mirror one stock, one recover $25 each
spare tire $20
jack and lug wrench $30
front spindles sandblasted w/ newer power stop rotors, bearings $100
200 r 4 trans, worked well before removal, 40 k car $600
defrost switch $7
Coolant tank $15
Blower resistor $7
Oil filler neck $10
Horn ring $12
turbo shield $7
p/s resevoir $50
down pipe $25
crossover pipe $35
stock headers $90
drive shaft $25
heads $100
Pulleys $65
rear view mirror $5
Newer IAC $30
NIB washer lid $10
Ash tray $10
intercooler fan $20
intake hose $7
86 ECM $75
Upper plenum $30
spare tire $20
