champion makes rails for the stock intake (doesnt matter if its ported)
they are available for stock fuel lines and stock style regulator
or can be had with a shortened driver side rail for external regulator and with fittings for feeding with AN lines
or you could even do a dual feed dual output to an external regulator
Yeah, unfortunately it is already on the way...I did tell them I wanted the stock style fuel rail but I wasn't sure if you had to specify stock style regulator and stock fuel lines? Of course the drivers side should be taken care of like you said but the passenger feed line is the one I am trying to figure out. I have been looking all over the Internet trying to find the right fitting or series of fittings but I haven't been successful. As I understand it I need an -8AN short oring male fitting X 16mm Saginaw female fitting...am I right?pretty sure whoever you use to order them from champion should be made aware how you would like them setup, they can be had for stock with fittings for the stock saginaw feed line , the driverside rail for stock regulator would work with the factory return line because thats at the regulator
No luck with that online either. I have tried several times to call Champion but have never gotten them on the phone and then tried several times to email them over the last few weeks and haven't gotten a response from that either. I guess I will just have to wait until Tuesday when it is supposed to arrive and then figure it out from there. Thanks for your help!!!the rails (all ends ) are tapped for -8 ORB (oring boss) basically -8 straight with an oring
the "stock rails" should have the M16 1.5 saginaw female end on the passenger rail
