REGALTURBO
I Am The Master..Master..
- Apr 20, 2003
Funny thing has been happening. This is the third time that this actually happened to me recently. When I shut the car off and attempt start it back up relatively soon, it starts really hard. Seems like it is flooded. Barely runs, like it is on 3 cylinders, and then revs to 3 grand and stays there. I`m not sure how long it will actually run this way because I shut it off pretty quick.
Then I will just start it right back up and its fine. I just know its not normal.
Only thing I`ve done to the car this year is this....I installed a new Walbro 340 fuel pump and also a new fuel tank. Installed Razors Alky system. Still tuning and working it out. And obviously switched to a TT alky chip.
Today I put on a hood mounted fuel gauge do double check pressure. Set at 42lbs line off and monitor driving, WOT pressure. Staying around 37-38lbs. Is this normal?
The only other thing I`m noticing is it may be happening after I make a short or long WOT run. Whether its a full 1000ft or 1/4 mile run or even a short holeshot and I shut the car down, it does the start hard and rev thing.
Something else I`m beginning to wonder about. And I may be late on this one, is....the only place I buy my 93 octane gas from is a local Sunoco station and I noticed today the "contains 10% ethanol" sticker. How or can this be effecting my car? Is 10% enthanol in 93 pump gas actually giving our cars an advantage or is there another tuning approach to using this gas.?
