straycat990
Senior Member
- Mar 11, 2002
I have decided to sell off my stage 2 parts, the following will be sold as a package deal. I do not want to piece it out.
$3700 firm
specs on the block are as follows
bore size 4.004
lifter bores bushed
front and rear caps are cross bolt mains
one cyl has a sleeve (has been run since sleeve was installed)
No Welds or cracks
Block needs line boring. ( block came out of a road course car ...had fluctuating oil pressure last lap. number 3 and 4 main had the bearings get welded to the caps (they did not spin). The block was fine, no damage at all. I also have 2 new caps to replace the damaged ones.
David
- 153 on center block
- matched set of 6.200 carrillo rods w/sps rod bolts
- BMS 3.59 crank turned .030/.040 ready to use, fresh out of machine shop
- set of isky solid roller lifters & rev kit
- BGC intake for on center stage 2 (new)
- comp cam billet solid roller cam dur @ .050 232/232 lobe lift .350/.350 lobe sep 112
$3700 firm
bore size 4.004
lifter bores bushed
No Welds or cracks
David
