On the highway the other day my speedometer went nuts. I had the cruise set at 65mph and all of a sudden it started really accelerating. Glanced down and the speedometer had shot up to 100mph! Then it dropped down to around 50mph and then back up to 110mph! Then I disengaged the cruise. About 1 mile later it jumped up and down a couple of times and then quit completely. BTW, this was with temperatures in the 30's. Now that it has warmed up to the 50's it will work from a dead stop up to about 50mph with a little jumping around and then drop back to nothing. I unscrewed the cable at the joint and could spin the top part by hand and the needle would move. I then took off the cable from the transmission. I took apart the little box with the metal gears inside and they would all turn freely. Also the bottom cable would turn freely. What is making it drop back to zero when I get up to around 50mph? Oh, and I'm also getting the code 24, vss. Thanks, R.B.
