Whats up guys, new member here needing some help. I've searched the boards and can't find any answers to my issue. I purchased an 87 GN last year and have been slowly getting it up and running. The speedo never really worked to begin with so here is what I've done to try to fix it..
I assumed it was the cable, so replaced with a new one. Put it back together it still doesn't work. I then pull the cable from the tranny and spun the wire with a drill and my speedo reads. So the cable and connection to the gauge cluster is good.
My next assumption was the speedo drive gear in the tranny, so I removed the speedo housing and pulled out the gear and the blue plastic gear looks fine. Checked the inside of the gear shaft and it is square not not rounded off. So now I'm clueless, and put it back together and take for a drive. While driving I accidentally knock it into neutral and all of a sudden the speedo jumps up and reads steady. I put it back in drive and speedo drops and reads 0, put it back in neutral and give it a little gas and it jumps right back up and reads again...I have no idea what to look at now...any ideas? By the way the car is bone stock.
