I've always liked the NGK V-Power plugs and used them in my first GN back in 87 with no problems, but I can't remember if they were UR4's or UR5's
I've read on this board to use NGK UR5's but the book calls for UR4's! Which is the correct # ? The UR4's would be a colder plug correct?
The reason I ask is that I'm still getting some detonation with a Thrasher 92. The only thing I haven't tried are different plugs. I'm running the UR5's.
All repairs, replacements, and mods listed below:
100lb valve springs
new GM coil pack
new Taylor 8mm S/P wires
Trasher 92 chip
3" THDP and dump pipe
Walbro 340 + hot wire
New GM fuel filter
Billet FP regulator
FP set at 45 psi
3" ATR dual exhaust
Big Mouth cold air
TPS and IAC set correctly
Flush IC + bypass VC breather
GM Top Engine Cleaner
Stock waste gate actuator and new Y hose assembly.
Checked all vacuum lines
I'm running amoco premium (93) and 3 gals Cam2 114 per tank full. Still get audible knock on hot days. Every time I get a chance to hook up the OTC it's cool out and no knock!
I ran 5 gals of Cam2 114 to 1/4 tank pump gas at the track this past weekend and no knock! Car ran 13.40 @102 on stock tires.
All is well except for the annoying knock on pump gas!
Things I still have to do:
Fix or replace DS header
Replace PCV Valve (kept forgetting to order the damn thing)
Clean injectors
I will be doing more scan tool testing this weekend. Any thoughts or suggestions would be appreciated.
100lb valve springs
new GM coil pack
Trasher 92 chip
New GM fuel filter
Billet FP regulator
FP set at 45 psi
3" ATR dual exhaust
Big Mouth cold air
Clean injectors
