Maybe get a drill rod and drive it into the center of the shaft. Also, if you drill and tap the holes for the retainer buttons, you could install cap screws with brass washers instead of the silly nylon butons. (use lock-tite) I don't think epoxy has ANY shear carrying capabilities. (though it might dampen harmonics) I will look into doing this myself in the next day or two. I guess that is why I recieved the std replacememt shafts from TA when I ordered the HD shafts. At least they didn't charge me for HD and send me std ones. The Sealed power ones are about $60 from TA, So, $80 sounds too steep for a standard replacement shaft. (Sealed Power) The Sealed Power shafts NEED the RJC caps, or you can crack them on installation. (just had that happen to me.) Sealed power lists the shafts as a heavy duty replacement for stock shafts, when in fact they are nearly identical to stock shafts, only heat treated differently. (which makes them brittle and if you torque the mounting bolts too tight, they WILL crack.) Some one is making solid shafts for the roller rockers, so maybe T&D could help you out?
