Stock 86/87 Parts
Alternator – $60
Knock Sensor – $20
Coolant Lines to intake – $45
EGR Valve (attached for inspections, it was blocked off) – $25
160* Thermostat and Housing – $35
Intercooler, scoop and shroud – $125
Cam – $20
Valve Covers – $35
D5 Converter – 50
Ignition module/Coil Pack – $100 , $115 w/ bracket
Rocker Arms – $20
Cam Sensor – $50
Rear Sway Bar – $30
Fenders of a Turbo T - $50 each
Power Steering pump - $60
Belt Tensioner - $50
Crank Pulley - $30
Performance
PTS ChromeMoly Flexplate (external balance) - $135
Taller Valve Covers - $50
Heated O2 Sensor - $50
Metco Upper & Lower Control Arms - $450
Hotchkis Sway Bars - $300
Comp Cam Push Rods - make offer
8445 heads (competition valve job, dbl springs, bowl blended, port match, chamber work) - $300
Short Block – 30 over, JE Pistons, balanced assembly, 215/205 Comp Cam, Meziere water pump – $1500 obo (had a throttle plate bolt go into the engine, piston and rings need replacing – had some blow-by, cylinder walls are fine)
Alternator – $60
Knock Sensor – $20
Cam – $20
Valve Covers – $35
D5 Converter – 50
Rocker Arms – $20
Cam Sensor – $50
Rear Sway Bar – $30
Crank Pulley - $30
Performance
