Does the car have stock motor mounts? If so, does it have a ratchet strap from the alternator to the frame?
If not it could be your downpipe tagging the a-arm. Pretty common issue that would cause a reading of 30+
Definitely sounds like false knock.
Future-GN-Owner,
I was running up to 28 psi with that SMC so it is fine.
The only reason I changed was MPH was getting up there for single and 93.
I assume they are the stock mounts and yes it has a ratchet strap and its nice and tight. Pretty sure its false knock. Just plugged ECM wire back in and gonna go for a drive and see if there are any changes. Matt
Sorry one more question. What is the optimum O2 number I want to see when running with the alky. Before I was usually around .820-.830 and now it seems about .770-.790ish. I know lean is mean but I dont want to hurt anything. IIRC the instructions said never to go below .720 Thanks again. Matt
AKA WB (hint )
Glad you got it working.
0.820-830 is RICH!
From comparing lots of logs between NB and WB, I would say shoot for 780-790.
As you incresae boost, you spray mopre alky, so you try to get into the high 790's. (WATCH FOR KR!)
Hard to say without a real O2 sensor, AKA WB (hint )
