Anybody have them? Mostly the mounting brackets, also the two routing valves.
These brackets seem to be unique to G-body Carb Turbos without air conditioning:
1. An alternator adjusting bracket, which attaches at the water pump, which has provision on top for the smog pump swivel bolt.
2. A front adjusting bracket for the smog pump, which also attaches at the water pump.
The smog pump itself sits above the water pump in the middle of the motor. The whole setup for the two routing valves over the steering pump is the same as for air conditioned cars.
I assume every reasonable person who can get away with it removes every trace of the smog pump. But I also assume most cars have air conditioning, and therefore most reasonable people would not have these parts.
