grandwazoo
- Dec 27, 2003
I continue to find more curiosities with my Basket Case GN.
While poking around with some wiring replacement I found a new wrinkle. The vapor cannister which sits behind the driver side headlight has two vacuum lines from the top. I found the one that leads to the fuel tank is in place and connected, however the previous owner had disconnected the line to the Vacuum Connector Block at the valve.
I'm hoping this will explain why I had to get a waiver on my emmmisions test when I licensed it and why from time to time the engine will die when decelerating.
The reason for the emmisions failure was the amount of unburned gas fumes in the emmision.
