Sept Update / Scan Tool Results ??, Knock ?
GNregistry
2 Questions: My Car is running GREAT, almost tuned...
1. How does the knock gauge work and how can you tell when it is bad and not the engine... for example... lately it seems to go "green yellow red" to the beat of a song or cruising down the road with no foot on the pedal...
could the rough roads or a simple problem, it never happend until recently driven twice now... I have instant acceleration 0-15 pounds boost hitting at 2nd shift chirps the tires... nothing seems wrong witht the car, yet the gauge comes on like xmas tree cruising... I'm thinking somethign is loose with knock gauge... for it to come on twice in past week or so...
2. What do my SCAN TOOL numbers mean???
Fuel Pressure at 43 line off
NGK UR5 Spark Plugs .030 TIGHT
Replaced Spark Plug Wires, Coil Pack, PCV
AC Delco 52 Oil Filter with ZDDP
I've made some changes to my setup
and currently it seems my BLM is consistently at 115, 117 ever since I've owned the car March 2008 and made changes...
My Last numbers Aug 27 - Sept 16, 2010
O2=757, 789, 820, 800, 773, 808
AF=6, 7, 6, 7, 6, 8
L8= 37, 44, 39, 42, 38, 58
Bat= 13.3, 14.0, 13.8, 14.0, 13.4, 13.1
INT= solid always 128
BLM=115, 117, 117, 117,117,115
ATS=116, 72, 88, 66, 74, 121
r=825, 900, 825, 900, 850, 775
tps= solid always .44
IAC=20, 53, 25, 49, 32, 52
Some people have mentioned that I have ERIC tweak the chip... whatever it takes! send new chip... please
TT 93 Chip/60 pound Injectors.
87 GN Hard Top, TA 49, 3" SS Dual Exhaust, 3" FMIC, 3" DP Ext WG/Boost Controller, TT 93 Chip/60# Inj, Scanmaster/Boost/Knock, F Body Alum. Rad. w/Dual Fans, RJC PP, XP Plus, Hot Wire Kit, 160 T-Stat, HRpartsNstuff: Dbl Adj. Upper & Lower CA, Dual Air Bags, Rear Anti-Roll/Super Swaybar.
Questions//comments
Sept 29 UPDATE: INSTALLED LS1 MAF/Translator = ALL GOOD!
Replaced stock MAF becuz of higher than normal AF #'s.
Therefore, started the summer 2010 with 20#'s boost, no knock = bad fuel.
Replaced O2 Sensor, only to replace it again - one month later with heated O2 sensor...
Added or Replaced spark plugs (NGK UR5 gapped tight at .030), wires, ignition coil pack, hotwire/fuel feeder kit, LS1 - 3" MAF with Translator, stainless steel exhaust hanger.
Scanmaster Numbers as of Sept 29, 2010 with new maf/trans.
up to 20 #'s boost
O2 = 734
AF = 4
L8 = 32
Bat = 13.5 - 14.0
INT = 128
blm = 121
r = 800
tps = .44
IAC = 28
line off 43 psi fuel pressure
Looks ok. You could leave it as is. However, if you want to bring the idle BLM up a little more, you can change the MAF BASE setting (inside the Translator), to "5". You should have already had it at "3" to start with for the 3 in. MAF. "5" is the slightly leaner setting. After you change it, I would reset the ECM to let it learn over again.
Eric
Thank You
I saw instant changes and then wondered what needed to be changed first, to raise blm... 5 it is... thank you
Wish I would have updated maf and translator when I updated chip and injectors...
FINALLY TUNED w/Turbo Tweak 93 Chip, Injectors, LS1 MAF with Translator
OCTOBER 2, 2010 -- TESTED CURRENT SET UP
good up to 20 pounds boost... no knock...
Installed LS1-3" MAF with Translator along with
Turbo Tweak 93 Chip & 60# Injectors, translator base setting = 5.
SCANMASTER RESULTS after road trip, taken at idle.
02 = 792
AF = 4
L8 = 30
bat = 13.7
INT = 128
blm = 126
mph = 0
CLT = 170
ATS = 124
r = 800
TPS = .44
IAC = 21
For those attending GS Nationals - October 2010, see ya there, I'll be driving from Auburn, Maine to Bowling Green, Kentucky in a 1987 GNX Clone...
After the GS Nationals, I'll have an updated time slip with street tires and current set up with parts, as listed in signature...
Thank You!!!!
TurboBuick.com, GBodyParts, HRpartsNstuff, Kirban Performance, Cotton Performance, RJC Racing,
Turbo Tweak, GN1 Performance, Red Armstrong, NOS4GN, Full Throttle Speed
