tom robison
ALL UP IN THEM GUTZ
- Dec 11, 2004
After a small mishap in bowling green this year and the means to be able to afford a new TA block, I have decided to sell my damaged block with rods and pistons. Here's what I have.
Block is a 4.1 153 stage 2, has been fixed at the motor mount area and 1 sleeve. Bore is 4.025. There is a burn hole between cylinders number 3 and 5 and a crack from the burn hole to the bottom of the cylinder. The block needs 2 sleeves to fix the burn hole and crack and honed to fit pistons. Cylinders 1,2,4 and 6 are ready as is.
Pistons are Venolia 4.025 bore 9-1 comp and are for 6.5 rods and 3.625 crank.They have 9 passes on them.One piston is brand new. When I bought these pistons in sept, I ordered a spare, I burned a hole in one in bowling green when block was damaged. These pistons are for 6.5 rods and 3.625 crank.
1200.obo
Scratch and Dent Stage 2 pictures by tomrobison - Photobucket
1200.obo
