scary scanmaster readings
Onalky87
while driving around under normal to light throttle the car is showing KR at random times. anywhere from 2-40kr and the recall says its happening at a mph that i did not achieve. (sometimes 101 somwtimes over 200mph!!) and sometimes the recall says the o2 readings to be 000 when it acts up under normal driving, before the knock comes up the scanmaster will either show all dashes across it or show 2.1 like i just turned the key on
also car seems to have no power and can not get into any kind of throttle without KR by even when it shows only 2kr under heavier throttle the car seems to have no power and act like trans is slipping and not picking up enough mph
How does your Voltage look ? must be consistent above 12.5V. Does you Volt light come on at all when you drive & this happens ?
