Alright I'm sick as a dog but just got a scanmaster 2.1 from a member and thanks to him. I just sneaked out and installed it. The car had no codes prior to installing scanmaster. I installed it set the iac numbers and tps settings as per instructions from prior threads. All as well worked out fine. Then it started to run rich at idle and two mal codes 22 and 44. code 22 is tps code 44 is 02 sensor. So here are the numbers.
o2 33
af 04
l8 32
bat 13.4
int 128
bl 150
mph 0
clt 198
ats 91
r 625-675
tps .44
iac 25
cc 100
need advise please
o2 33
af 04
l8 32
bat 13.4
int 128
bl 150
mph 0
clt 198
ats 91
r 625-675
tps .44
iac 25
cc 100
need advise please
