granitestategn
Gettin' there
- Jul 30, 2002
Hi guys,
First time poster in the S2 area. I live in New England and need to wipe out my bank account (J/K). I have had my GN since new and I love it. I am no where near even maxing out my mostly stock set-up but have a line on a refugee engine from a BGNN car. I have been told it has an aluminum block with aluminum heads. Obviously N/A. It is rumored to be one of the better engines of a bunch they let go when they switched to V-8's. Fairly fresh. I have not seen it and don't know if I can get it. IF I have the opprtunity to pick up this motor, what should I look for as far as what is desireable and what to watch out for. You don't need to start at square one for me ( I hope) because I've already done a lot of searches on this forum and others. I would like to put this in my GN for mostly street use of around 1000 miles per year with some strip duty. The track is 45 minutes from the house, I would not trailer it. I would shoot for a goal of a solid low to mid 10 second car that would be "streetable". This engine would be a long term project with a secondary goal of keeping cost to a resonable level. I know, "Stage II" and "reasonable cost" don't belong in the same sentence. Consider me forewarned. I know RPE does a good job on Buicks so I would probably lean in that direction for machine work and balancing. I know cylinder head chamber volume is a big deal, kind of the more the better. I don't know everything there is to know but I believe all the BGNN cars would be 4.1 L engines. I would think I could use the crank, heads and block. Valves would need to be replaced w/stainless. Run the dry sump or convert to external pump wet sump or Dutt oil system. The intake could be modified for FI or you can get a sheet metal mainifold from Hogan or others. Headers can be a problem ($$$$). Engine management can run into $$$$$. Has anyone run a MAFT Pro w/WB02 on a S2? I know most guys are running more exotic systems but considering the ET's I'd be looking at, I may not need it. I would probably be looking to pick up good used parts from, frankly, guys like you.:wink: Are most BGNN engine blocks aluminum or is cast common, too? What are the pitfalls of running an alum/alum engine on the street? The obvious advantage to aluminum is weight. To my way of thinking, repairability should be another plus. Just a few questions for you guys to mull over. Forgive me if you've had to answer them before. Happy Easter!!
