This could be a long one...
Where to start...well, I had 009's and stock maf running pretty good in the car. (stock turbo, stock longblock, walbro340 & AFPR etc) I put on an LS1 maf, T+ (version 6.0 I think), extender chip rev E, msd 50# injectors. Nothing but rich now.
I've gone through weeks of trying this and that and replacing things. I've replaced the plugs a few times (keeps fouling them) new ign module, new accel coil, new GNX style 02 twice, wires ohm out good, new crank pos sensor. I checked the tps for dead spots, tried a tps-tec as well. Took all the injectors out and tested them, one seemed to have a weaker pattern than the rest, so I swapped it with the spare injector that was good. Run lots of xylene through them.
My BLM's are low and 02 is very rich. My extender chip is BSL54A0E, I have the T+ set to on on off off, dips 2,0,0,A Currently at 40# fp hose off, have tried it down to 35# no change.
I don't have any options set in the chip, so 12 is 0.
As to any other questions on #'s, I've made several turbolink recordings in the past few days. I'll post them. I noticed last week (test3.ECM) that once I got it out on the interstate in 60mph cruise it was trying to lean out better. Odd thing I can't figure out is why it won't stay in closed loop. Does it automatically go into open loop if the 02 rich code is thrown?
I've probably forgotten something I've done, but any suggestions are welcomed...thanks in advance.
http://65.5.163.175/test3.ECM
http://65.5.163.175/test4.ECM
http://65.5.163.175/test5.ECM
