tminer
Not quite normal
- May 25, 2001
I set my ATR 7th (circa 1992) to run full time by bypassing the hobbs switch. The only problem is that it runs the injector static when I turn on the ignition. If I quickly turn the key from off to start then it works very well (fires the 7th with same pulse as one of the other 6).
Is this normal or is mine maybe defective?
Is there a +12v tap that is only on when the engine is cranking or running?
Any ideas? I don't like using the alternator charge cicuit and the oil pressure switch is wired in parallel with the fuel pump timed relay.
Thanks,
Tom
Thanks,
Tom
