I was looking to use the green output connector that is located just forward ot the drivers side valve cover to turn on a dash lite at a designated RPM. I called Summit and they suggested I buy the MSD RPM Activated switch and the MSD Module that has a dial ranging from 6,000 to 8,500. For Ex. set the dial at 6,000 and any lite I have mounted in the dash will come on at that RPM. I ran the wire with the Green connector to the RPM inlet of the Activatd switch. However - at 6,000 the lite does not come on. I called MSD and they told me It depended on what kind of signal comes out of the wire with green connector. He said , if its a Minimum 12 volt Square Wave 20 degree duty cycle or a volt spike negative pulses 1 per revolution - that it should work. I am not an electrical guy- sounded all greek to me.
Can anyone tell me what type of signal comes out of that connector?
If not- is there a different wire I can get a RPM signal out of to run to this MSD module. I am running a fast sys - possible that illiminated any signal coming out of the green connector?? Larry
