Roller rockers
Zacks 85GN
Zman
Due to a botched valve job I and going to have to run roller rockers so I can have some adjustment. The valve stem hight is all over the place and I don't want to have new seats installed.
Which brand do you guy's like the best?
1. T/A performance
2. T&D
3. ATR
4. Harland Sharp
Thanks for any advice,
Jim Willett
T/A performance sells T&D roller rockers. Major difference is T/A supplies a stud mount kit with theirs instead of bolts. Once you use the studs, you will never go back to bolts. For aluminum heads, studs are a must item.
Jack Cotton is also a T/A distributor if you are in that part of the country.
