Since it seems I can't find someone selling a set of 3.42 gears for 30 spline axles...can someone post a link that would be a good place to purchase from....
The gear won't have anything to do with the spline count on the carrier. You need a 3.42 matched gear set for a GM 8.5" car rear. There are some 8.5" truck gears but they won't fit your carrier.
Are you trying to change to a different carrier so you can go to a higher spline count?
Then all you need is the gears for it, but if you drive it on the street a spool will squeel the tires as it goes around corners and give you issues in wet weather.
Yes it has a spool already...I just need the gear set....I don't drive the car in the rain....and yes it does squeal a little but not much...should I just order a set of Dana ring and pinion set or what brand....
