Right Rear wheel Cylinder
Hyboost
Hyboost
I need to replace my right rear wheel cylinder. The previous owner said he replaced both with S-10 blazer cylinders.
First off, does anyone know what year blazer I should get the cylinder for?
And secondly, how do I know (Before buying both & comparing) if they even are from a blazer and not stock? Thanks.
I think I installed an 85 blazer in mine. But I'll double check. Use the search feature (that's what I did) and there's a thread that has part of the info you want (which year blazer cylinder).
Great, thanks. I did a different search & couldn't find it. But tried again and found the info. Thanks again.
I know this is an old post , how do you find the S10 wheel cylinders ? ok for normal driving ?
You wont notice a difference in driving. You can just brake and hold more boost at the line over the stock wheel cylinders. Drive ability wont be affected at all.
