Parts for Sale :
1. 76 Turbonetics Q Trim Turbo (ran 9.70s with) $700
2. Two 109 blocks $325 each
3. Two turbo cranks Price Pending
checking to see if need to be turned
4. Four sets of 8445 heads $25 pair
5. One cam sensors $75 ea
6. Three MAF Sold
7. Three stock intakes $250 ea
8. Four Doghouses $40 ea
9. Three throttle bodies $70 ea
10. Three sets of valve covers $30 pair
11. Four front covers $50 each
12. One stock up pipes $20 ea
13. 15 gallon Fuel cell RCI with GM sending unit & straps $150
14. GN Radio with EQ $50 fair shape
15. Power antenna assembly (used) and spare internals (new) $75
16. 307 V8 wiring harness $25
17. Crossover with two deltagates attached $200 (one gate needs rebuilding)
18. Three side directional markers $75 for all three
19. Two yellow directional lenses $25/ pair
20. One chrome directional marker $25
21. One Fuel injector harness $40
22. Two stock Fuel Pressure regulators $10 ea
23. One steering box $50
24. One negative battery cable $10
25. One coil pack $25
26. One stock turbo inlet bell $10
27. One stock trans dipstick & tube $25
28. Two Turbo 400 dipstick & tube $15 each
29. One stock air intake assembly $30
30. One set stock brake lines from MC to prop valve $25
31. One stock steering wheel-needs to be recovered $75
32. Four oil dipsticks-no tubes $10 ea
33. One set GN rear spoiler caps $75/ pair
34. Two stock fuel pump hangars $125 each
35. One four bolt turbo .69 housing $75
36. One aeromotive (red)-model 18201-needs rebuilding $75
37. One dump pipe with cutout-been repaired $25
38. One Autometer mechanical 2” oil pressure gauge model # 2623 $25
39. One Autometer mechanical 2” water temp gauge model # 2607 $25
40. One set of stock fuel lines $80/ pair
41. One pass side fenderwell for regular Regal $50
42. One set aluminum rear brake drums $80
43. Two powermaster $150 bought as spares, never used
44. One stock fan assembly $75
45. One rear bumper chrome-fair shape $50
46. One stock fuel injector rail $50
47. Tail light wiring harness $20
48. One set used Mickey Thompson slicks 29.5x 10.5x15 $50
49. One 4” Mass Air flow pipe (black) $100
50. One set Nitto Drag Radials 275x50x15 decent tread left $225
51. Stock gas tank $70
52. Four T Type rims with caps-no curb hits with four tires 215x65x15 $300 for wheels/ tires
53. One PROMPAQ chip holder-no longer made-switch between 4 chips with a turn of a key $175
54. One fuel rail with AN -8 fitting $75
55. One set of wires with set of injectors (green stripe on injectors) $200
56. One ATR four gauge holder for under dash $40
57. One fake battery for front-used when moving battery to rear $15
58. One set Crane 8mm wires $25
59. Two turbo oil lines $50 ea
Prices are without shipping, larger parts local pick up only. All parts sold as is with no warranties either express or implied.
6. Three MAF Sold
