Can't figure out where they go! 15mm or so with a lock washer. There are 2 of them. I used 1 for the cable bracket assembly that bolts to the plenum. Not sure if that's where it went. If anyone can track down a pic of the area it would be a huge help. I can get a pic if necessary.
Also, the numbers on the injector harness have worn off completely, is there a way to tell which goes where?
