B BASS Member Joined May 25, 2001 May 7, 2018 #1 Ok, I have a pinhole leak on the bottom of my stock crossover pipe. Before I have a chance to get it weld repaired, would JB Weld hold up? I don't believe the crossover pipe gets as hot as the headers, so maybe this would work?...
salvageV6 Daily Driver Joined May 25, 2001 May 8, 2018 #3 There's muffler patch stuff in every parts store it should work til you weld it. https://www.amazon.com/Permatex-803...coding=UTF8&psc=1&refRID=QPFSVT069X8J91BJM5JK
B Boost231 What's An Intercooler Staff member Joined May 26, 2001 May 8, 2018 #4 No need to fix that hole. It's small and it will help drain the moisture buildup. Just get it welded when you're ready Sent from my SM-G935T using Tapatalk
750H.P.V6 Brutal 6 Racing Joined Sep 4, 2001 May 8, 2018 #5 Slide a hose clamp over it to seal the leak until you can pull it off to weld repair it. Neal
