You will need to presoak the bolts (PB blaster, WD-40 or other type of spray) before you try to remove them if they have never been removed before.
You can also save some aggravation if you remove the 3 most accessible bolts first (the two on the drivers side, and the easy one on the passenger side). This will allow the x-over pipe to move far enough for access to the last bolt.
