Did you replace the connector that goes into the Alt? My VB plugs into the alt with 2 wires and I think stock only uses 1 wire. Guess I will have to buy a new connector from Capers? Part number 108057I took mine off after installing the alky kit. The car is very easy to tune and I have no regrets about removing it. I'm up to 25#'s on pump gas and looking to go further. Razor kit, yah man.
I had my stock connector, so I went back to that.
FWIT all you have to do is remove the vac/boost line to the VB and everything is stock/normal again.
Gary
