2004R out of an 85' GN, recently rebuilt with zero miles. Pump rebuilt with hardened rings, new vanes, bronze pump bushing staked in place, drain back passage enlarged and dual springs in pump. .500 boost and .296 rev boost valves installed. Selective and thrust washers replaced as required, 3 pack friction for fourth gear, GN servo, HP band, thicker steels used for tighter clearances in all clutch packs, Raybestos frictions, new seals and gaskets, Level10 shift calibration kit in BQ valve body, 700R4 bottom feed filter and weld-in drain plug.
Also have 87' 2004R with KT valvebody, rebuilt with same mods above except it has Transgo Shift Kit instead of Level 10. Both $800 with exchange or partial trade(s) for H&R or BMR rear swaybar, any brand rear upper adjustable control arms, billet forward drum (2004R) or any billet trans parts, small Corvette style starter that will fit GN, upper door seals (on body; glass rolls up into it), SMC alky pump and/or bottle, 4L65E core complete with LS bolt pattern. Several references available from board members. Thanks, John.
