BlackMagic
- Nov 20, 2003
I sold my GN to my dad, and we are trying to troubleshoot a problem.
The car will start and idle fine, and drive down the street fine. When you mash the gas much at all, the car has hardly no power. Looking at DirectScan I immediately thought I knew what the problem was...a bad MAF. The grams/sec reading only moves between about 5-11 grams/sec no matter how hard the throttle is pushed. We swapped in another MAF, same deal, and then took a known good MAF and had the same issue. We then tried all of those MAFs in another car and they worked fine.
The car has a Translator + and Extender Extreme chip. We sent the T+ back to Mike Licht and it checked out OK. With the key is in the ON position, car not started, one pin on the MAF has battery voltage, the other is seeing 5V. When the car is running, the one side remains battery voltage where the other goes to about 2.55 volts or so. We verified that same voltage is on pin B6? of the ECM while the car is running. Supposedly that reading should be 2.55 or so when the key is on and go to 2.48? or so when the car is running, but it doesn't, it remains at the higher voltage on both the ECM pin and right at the MAF. We have double checked the grounds on the back of the pass head, and even swapped in another ECM to try and isolate the problem.
Any other ideas would be greatly appreciated. TIA!
