I have read and read and the general answer is stay with a 3.42 but....
I looked at my datalog at the 1/4 mile line I was at 5450 rpm with a 1.0 trans ratio 129 mph with 28" tall tire and a 3.42 axle ratio @24lbs of boost When I plug all the #'s into a drag racing calc it's telling me convertor slip is 2.9% I believe my cam and engine combo has it's power range around 5-6250 rpm. my shift light comes on at 6k and shift occurs around 6150-6200 rpm I want the car to mph about 137-138 to put me into a high 9 with boost about 30lbs. using the info from the drag racing calc I plug the desired #'s in with desired rpm at finish line 6100 and I'm getting about 3.63 ratio.... I just purchased a 9" ford rear end for my car used and it just so happens to have a 3.7 ratio already in it. Before doing the above stated math I was going to put a 3.5 ratio in it. Are all of my ideas in the correct line to stay with the 3.70 ?
