Can anyone tell me how much oil the stock rear takes? I thought it wass 2 qts. but I put a qt and a half and a bottle of GM limited slip lube, and it seems to be full, just want to double check before I finish.
usually 2 qts will get it done so dont be worried if you didnt use it all
it depends on if your rear is level when you filled it
if its to the bottom of the fill plug than thats should be fine
