87GNattyKid
- Sep 25, 2008
To make an extremely long story short, i got my car repaired at a body shop after an accident and it took over a month and a half to get my car back. There were lots of headaches dealing with this shop and along with the body work they also put in a new starter motor.
I picked my car up yesterday and they seemed to have done good work but then on my way home the check engine light kept flashing on and the car would lose power until it stalled. When i turned it back on it would stall unless i gave the gas pedal some pressure. I thought maybe they put bad gas in it and i was able to get it to a station and fill it up with premium. When i got hom i popped the hood and noticed there was no coolant in the resovoir and the cap was also missing. I called the shop and they told me the cap was in the back seat, which it was, along with a big grease stain that wasnt there before...
Anyway, i filled the coolant, added the quart of oil that was missing from when he changed the oil filter which was damaged in the accident. After this i turned the car on and let it idle. I took it out for a short drive and everything seemed to run good. A few hours later i took the car out and it ran god unless i hit a hard bump the engine light would come on and it would lose power for a split second and then run fine (assuming it didnt stall because my foot is on the gas)
I was curious what could cause a problem like this? Could it be bad gas? Or do you think they did something to the car? I dont know why the engine light would only come on and lose power when i hit a hard bump...Could something be loose? Or could it just be from sitting for over a month in an auto body shop?
Im at a loss for what could be wrong and im weary of bringing the car back to this shop that i had lots of problems with.
