G GNasty Member Joined Sep 15, 2006 Jul 1, 2014 #1 Am I correct to assume the racetronix hot wire kit, bypasses the stock fuel pump relay completely (and only uses the racetronix relay)? Thanks
R RmvBfrFlght Well-Known Member Joined Sep 28, 2007 Jul 1, 2014 #2 No, the stock relay is used to activate the hot wire relay. The oil pressure switch will also activate the hot wire relay. RemoveBeforeFlight
