Went out and raced a buddy of mine on his 08 busa from a dig today, went well should have vid in a couple of days. I would call the race a draw but it was to close to call.
Good run ....but just know that a stock busa has the timing pulled untill third gear for safety sake as do most crotch rockets is stock form so they dont have full potential but the front tire tends to stay on the ground easier with this enabled..hence the safety aspect of the feature.
To eliminate this you can buy a TRE Timing Retard Elimnator
Ta alluminum block, solid roller,42r74 turbo, full weight car but has already went 115 in the 1/8th at 16 psi and leaving off the foot brake a 0 psi. Car will go 148 to 150 I would think.
