mods
Hi!
Well, you'd be running about $1500 less cash in your wallet, for sure. Just kidding. I have an '96 Riviera with the same package, and can say that the way to start is with the small pulley, then probably a cold air kit and reprogrammed pcm. That should take you up to a grand or so. After that, maybe a shift kit for the 4T65e, then I like the traction/ torque steer setup that thrasher sells. You're lucky, lots available for the Pontiac, not so much specifically for my Buick. Check out Thrasher- ep.com !
