excobraguy
- Feb 25, 2007
I have an 87 gn with 105k miles. I pulled the motor to install some upgrades. New rocker shafts, rjc head gaskets, new turbo, new torque converter, New timing chain.
I put it back together, the intake and turbo are not on. I held my thumb over the turbo oil feed line and using a drill I primed the engine. It sends oil up to the driver side rockers, no problem. It actually puddled up in the return holes. The passenger side however is very slow on sending the oil to the rockers. It only has a small amount that has came out. Is this normal? If not, what could I look for as potential issues?
