PT-70 just rebuilt. 3" inlet 2.5" outlet .63AR 3 bolt precision turbine housing P trim wheel. The wastgate hole has been enlarged. All new bearings and seals from Limited Engineering. It has the 360 degree thrust bearing that is attached with screws rather than the spring washer. Also includes the wastegate accuater. I went 10.50's in a full weight iron headed GN with this. It only has about 20-30 passes on it, no street miles. Was used with a "turbo saver". I went to a 70bb turbo. $750.00
