The best way to find out the optimum pressure is power brake with one tire at a time on the track scale. Add right rear pressure until the values are close equal at launch boost.
I've done this for my car. 25 psi in the right and no left, with a spare tire and about 1/4 tank of gas, the weights were close (within 20 lbs or so)
Adding gas to the tank increases weight to the left side and you need more right side air to compensate (opposite of what you would think). A spare tire provides right side weight and reduces the psi in the right side required to balance.
