I was driving down the road and all of a sudden 87 GN just stalls out. I pull over to the side of the road and it wont start, nothing no clicking from the started nothing, it was dead. I tried playing with the key in the ignition and I got it to crank for a second then it stopped, and it was dead again. So I had a friend tow it home for me. I just assumed that it was the ignition switch, so I changed it. I hooked the battery back up and it started, it ran fine, then I put it into reverse and it stalled, and now nothing works, no cranking from the started, no courtesy lights, no horn, no hazard lights, no brake lights, no nothing, its like there is no battery in the car, the only thing that works are the headlights, the parking, and dash lights that come on when you turn on the head lights, that’s it.
Things I have looked at:
I check that battery with a voltmeter it reads about 12.77v, I also load tested it and it ran about 740 CCA.
At the alternator it ran about the same, but only if I used the battery as a ground, if I used the fender it was only .6-6v, which means I must have a grounding problem, but I cant find it. If I used the motor as a ground the readings were jumpy.
I have looked at several grounds and they all seem to be fine, I even cleaned a few of them.
Is it possible for the ground wire from the battery to go bad, if so why do the headlights still work and nothing else does.
Any help please
chris
Any help please
chris
