Just pulled out the Monte SS trans out of my RX-7,again after the rebuild.
It has only reverse,this happened after a couple blasts out on some country roads around here.
With it out I have checked all of the things that previous posts had suggested as the problem.
The forward clutches are fine,the forward piston is fine too.
The Gov. and Gov. housing are good.
I am not sure where to check in the valve body.
The only problem I found,was after pulling down the seperator plate the piston that is in the opening up in the case(3-4 accumulator?)was very hard to get out may have been stuck all the way up. Could this have been the problem? if so how, and what would have caused this?
Any Ideas?
Thanks in Advance
John S
Any Ideas?
Thanks in Advance
John S
