http://s89053294.onlinehome.us/misc/mannycruz/carlos2.jpg
http://s89053294.onlinehome.us/misc/mannycruz/carlos3.jpg
http://s89053294.onlinehome.us/misc/mannycruz/carlos4.jpg
Copied this from another forum......
Manny Cruz's tube chassis sentra
Has made over a dozen passes, six passes being in the 7 second range and six passes in the eight second range. The best so far (that I know of) is 7.57 @ 179, car weighs 2450lbs.
945hp - 1117 ft lbs of torque
All this is done on the following setup:
stock block
stock connecting rods
stock pistons
stock head gasket
stock cylinder head
stock cams
stock cam gears
stock timing belt
stock crank
stock intake manifold(slightly modified)
upgrades:
suprs(2jz) coils
motec ecu
dry sump oil pump
ATI Balancer
81mm turbo
-10 fuel rail
liberty 5 speed tranny
liquid intercooler
Most of this info is from Victor Brouschet, member RB30DETT on supraforums
BTW, The motor is a Nissan 2.6L RB26DETT motor (aka Skyline motor)... Pretty darn impressive if you ask me!
stock block
stock pistons
stock head gasket
stock cylinder head
stock cams
stock cam gears
stock timing belt
stock crank
upgrades:
suprs(2jz) coils
motec ecu
dry sump oil pump
ATI Balancer
81mm turbo
-10 fuel rail
liquid intercooler
