I'm in process of rebuilding my Powermaster unit.
I have a couple of questions.....
If looking at the Power Piston Assembly, there is a thing that looks like the needle that is used to pump up a basketball or football.
It is called the "REACTION PISTON" and is located at one end of the power piston assembly.....
There is a groove on the main body of this small piston.......
QUESTION #1 - Is there supposed to be a small O-ring in that
groove?? (or is what looked to be an old O-ring
in there, when I removed it, just some mush from
the old reaction disc from the other end of the
assembly???)
QUESTION #2 - Is the secondary piston already part of the
primary piston assembly in the rebuild kit??
I can't take any of the primary piston assembly
apart, but according to the Instructions and
diagrams I'm using, there appears to be
something called the secondary piston assembly,
but I sure as hell can't find it!
My primary piston that I took out is stamped E14 so I'll be using that one from the rebuild kit that I purchased down in Bowling Green. That means that the other piston assembly that came with the kit (stamped E11) will NOT be used. That, I understand perfectly, but what other parts will not be used from the rebuild kit? Anyone know?
I will be using 3 large O-rings, one small O-ring, the check valve seat assembly, and the poppet and spring assembly, but what about the two other wider rubber o-rings, or seals, that come with the kit? I can't see where those would be used, if I follow the directions that came with the kit.
As most people have said, this is not really that hard of a process, but the directions are a bit fuzzy.... they tell you to remove secondary seal, primary seal, and spring retainer from secondary piston, but where the hell is the secondary piston??
Is it part of the primary piston, but not removable from it??
Isn't all of that already part of the new primary piston assembly that comes in the rebuild kit?? So what is it telling me to remove any of the old seals etc.... if i'm not going to be using the old piston anyway?
If you've rebuilt one of these, and you can help straighten me out on these few questions, THAT WOULD BE GREAT!!!
Thanks to everyone on this board that gives of there time and knowledge!
Tim
assembly???)
Tim
