Wondering if anyone else has this problem and how to fix. When I have PL monitoring and use the line lock, PL just freezes up. Sometimes I can simply switch from monitor to review mode and back, but most of the time I have to shut down PL and restart it. That's a bit of a hassle to do right after the burnout. The guy in the other lane thinks I'm burning him down and gets PO'd.
Testing it in the garage, I can cycle the line lock a few times and same thing happens. I rewired the line lock to take a power source from under the hood instead of the fuse panel (put a fuse in-line) and then ground the line lock to the chassis (power going through my B&M shifter switch). I rewired it because it used to do the same thing when taking power from the fuse panel direct to line lock solenoid and then ground through the switch.
Any ideas? Thanks!
Any ideas? Thanks!
